RV042 VPN problem
Jul 11th, 2010
I want to connect VPN between my two offices. It was working fine but after some power failure we had to restart the router but then the router is working but VPN is not connecting. i have the following scenario between my two offices:
The VPN tunnel continuously shows Waiting for connection at both ends. I can see the packets of VPN intial mode at one site but there are no VPN logs at other site.
can someone help.
Kind regards
Zeeshan
zeeshan.kamal Sun, 07/11/2010 - 22:26
My other VPN box is working perfectly. I tried to configure a VPN tunnel with my other Rv042 box and it works fine. but this one is not working fine. and is not showing any VPN logs. Does anyone knows where is the issue.
Kind regards
Zeeshan Kamal
