Agent Reskilling CCX 7.01
Answered Question
Jul 11th, 2010
How can I perform agent reskilling in CCX 7.01? Is necessary to perform it have assigned Administrator role?
If we change a skill to an agent, is necessary that the agent logs out to refresh her skills?
Correct Answer by Jonathan Schulenberg about 6 years 7 months ago
Click on the resource name and modify the skills and/or competency level for that agent.
Yes unless you have also granted the supervisor role access to /appadmin by changing the system parameter for supervisor access.
No
Overall Rating: 5 (1 ratings)
Correct Answer
Jonathan Schulenberg Sun, 07/11/2010 - 09:11
No
antonio.vazquez Sun, 07/11/2010 - 09:14
Thank you Jonathan for your response.
Regarding "granted the supervisor role access to /appadmin by changing the system parameter for supervisor access", how can I perform it? Is necessary to restart any server from the cluster?
Thank you again.
antonio.vazquez Sun, 07/11/2010 - 09:25
I have changed th system parameter and all works fine.
Thank you for your help.
Related Content
