SNMP TRAPS and SLA
Jul 11th, 2010
HI
I am trying to configure IP SLA to send SNMP TRAPS but looks like doing some mistake ..
i have following configured
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin;}
ip sla monitor 2
type echo protocol ipIcmpEcho 150.1.3.3 source-ipaddr 1.1.98.7
frequency 10
ip sla monitor schedule 2 start-time now recurring
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin;} ip sla reaction-configuration 2 react rtt threshold-type immediate action-type trapOnly
ip sla logging traps
snmp-server community public RO
snmp-server enable traps rtr
snmp-server host 1.1.128.226 public
1.1.98.7 is the loopback ip on my network. To test the snmp traps, i enabled debug snmp packets and shutdown loopback interface (1.1.98.7)
I don't see any snmp message in debug output ..
am i missing something or it is not possible to get traps directly from ip sla .. do i need EEM for this?
Joe Clarke Sun, 07/11/2010 - 22:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I think you need to add a reaction for timeout instead of rtt.  What is the status of this IP SLA collector?  I have a feeling it's in a timeout state versus an over threshold state.
Lokesh.Khanna Sun, 07/11/2010 - 22:28
HI
Yes, it is in Timeout state.
WIll it not treat as high RTT if it is down .. specially If the latency is above 5000 ms (default reaction cofniguration for RTT)
is there any way i can simulate the latency on rtrs ..
Joe Clarke Mon, 07/12/2010 - 08:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The collector has to complete for RTT to be high.  If it times out, it times out.  If you have some kind of QoS policy you can use to rate-limit the IP SLA traffic, that could be used to bump up the latency.  Else, you can artificially lower the threshold or just configure a timeout reaction to test trap functionality.
Lokesh.Khanna Mon, 07/12/2010 - 13:59
HI
I just tested traps using timeout option and it works ..
but it worked for me even if i didn't have "snmp-server enable traps rtr" & "ip sla monitoring trap"
Why do we need those commands if it works without them also ..
Joe Clarke Mon, 07/12/2010 - 15:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You only need "ip sla monitor trap" to produce syslog messages.  You will need to enable IP SLA or rtr traps, though.  What config did you have which produced a trap?  What trap did you receive?
Lokesh.Khanna Tue, 07/13/2010 - 13:08
HI
this is my cofnig -
ip sla 1
icmp-echo 65.65.3.3 source-ip 65.65.2.2
request-data-size 1500
frequency 10
ip sla schedule 1 life forever start-time now
ip sla reaction-configuration 1 react rtt threshold-value 5 1 threshold-type immediate action-type trapOnly
ip sla enable reaction-alerts
logging trap debugging
snmp-server host 150.150.1.1 public  ipsla
R2#sh ip sla reaction-configuration 1
Entry number: 1
Index: 1
Reaction: rtt
Threshold Type: Immediate
Rising (milliseconds): 5
Falling (milliseconds): 1
Threshold CountX: 5
Threshold CountY: 5
Action Type: Trap only
R2#sh ip sla statistics
IPSLAs Latest Operation Statistics
IPSLA operation id: 1
Type of operation: icmp-echo
    Latest RTT: 12 milliseconds
Latest operation start time: *16:01:33.914 UTC Tue Feb 15 2000
Latest operation return code: Over threshold
Number of successes: 176
Number of failures: 0
Operation time to live: Forever
Am i missing something here. As per the sla stats, return code is over threshold and as per react-configuration, i am supposed to get snmp alert ..
if i change my react configuration to timeout, then i immedailty get snmp traco as soon as destination is not reachable ..
Joe Clarke Tue, 07/13/2010 - 13:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What is the exact trap you receive for a timeout?
Lokesh.Khanna Tue, 07/13/2010 - 14:02
HI
I just created another ip sla with timeout in react-config .. below is my config
ip sla 2
icmp-echo 65.65.100.100 source-ip 65.65.2.2
frequency 10
ip sla schedule 2 life forever start-time now
ip sla reaction-configuration 2 react timeout threshold-type immediate action-type trapOnly
snmp-server enable traps ipsla
logging message-counter syslog
*Feb 15 16:52:48.074: %RTT-4-OPER_TIMEOUT: condition occurred, entry number = 2
*Feb 15 16:52:48.082: SNMP: Queuing packet to 150.150.1.1
*Feb 15 16:52:48.082: SNMP: V1 Trap, ent rttMonNotificationsPrefix, addr 65.65.2.2, gentrap 6, spectrap 2
rttMonCtrlAdminTag.2 =
rttMonHistoryCollectionAddress.2 = AAdd
rttMonCtrlOperTimeoutOccurred.2 = 1
*Feb 15 16:52:48.130: SNMP: Queuing packet to 150.150.1.1
*Feb 15 16:52:48.130: SNMP: V1 Trap, ent rttMonNotificationsPrefix, addr 65.65.2.2, gentrap 6, spectrap 5
rttMonReactVar.2 = 7
rttMonReactOccurred.2 = 1
rttMonReactValue.2 = 1
rttMonReactThresholdRising.2 = 0
rttMonReactThresholdFalling.2 = 0
rttMonEchoAdminLSPSelector.2 = 00 00  00 00
*Feb 15 16:52:48.198: %RTT-3-IPSLATHRESHOLD: IP SLAs(2): Threshold Occurred for timeout
But i don't get traps from other ip sla instance which is monitoring RTT threshold values..
Joe Clarke Tue, 07/13/2010 - 14:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the full show run and show ver from this device.
Lokesh.Khanna Tue, 07/13/2010 - 14:26
sorry, it actually worked .. i just gave a restart to ip sla and it worked.
looks like router was already in threshold stage when i was activating reaction-config ..
but i am still confused which command is actualluy generating these traps since i have taken out some of the snmp config out and i stil get traps ..
below is the oputput of traps which i get when i restart ip sla .
*Feb 15 17:10:43.453: SNMP: 150.150.1.1 queue overflow, dropping packet
*Feb 15 17:10:43.453: SNMP: Queuing packet to 150.150.1.1
*Feb 15 17:10:43.453: SNMP: V1 Trap, ent rttMonNotificationsPrefix, addr 65.65.2.2, gentrap 6, spectrap 3
rttMonCtrlAdminTag.1 =
rttMonHistoryCollectionAddress.1 = 41 41  03 03
rttMonCtrlOperOverThresholdOccurred.1 = 1
*Feb 15 17:10:43.497: SNMP: 150.150.1.1 queue overflow, dropping packet
*Feb 15 17:10:43.501: SNMP: Queuing packet to 150.150.1.1
*Feb 15 17:10:43.501: SNMP: V1 Trap, ent rttMonNotificationsPrefix, addr 65.65.2.2, gentrap 6, spectrap 5
rttMonReactVar.1 = 1
rttMonReactOccurred.1 = 1
rttMonReactValue.1 = 12
rttMonReactThresholdRising.1 = 5
rttMonReactThresholdFalling.1 = 1
rttMonEchoAdminLSPSelector.1 = 00 00  00 00
*Feb 15 17:10:43.585: SNMP: 150.150.1.1 queue overflow, dropping packet
*Feb 15 17:10:43.585: SNMP: Queuing packet to 150.150.1.1
*Feb 15 17:10:43.585: SNMP: V1 Trap, ent rttMonNotificationsPrefix, addr 65.65.2.2, gentrap 6, spectrap 5
below is my running config and sh ver
R2#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(24)T1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 19-Jun-09 15:13 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
R2 uptime is 8 hours, 9 minutes
System image file is "flash:c2800nm-adventerprisek9-mz.124-24.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2811 (revision 53.50) with 237568K/24576K bytes of memory.
Processor board ID FTX0952C333
2 FastEthernet interfaces
4 Serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
R2#
R2#sh run
Building configuration...
Current configuration : 2233 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
dot11 syslog
ip source-route
ip cef
ipv6 unicast-routing
ipv6 cef
voice-card 0
vtp domain 29
vtp mode transparent
archive
log config
  hidekeys
interface Loopback0
ip address 65.65.2.2 255.255.255.0
interface FastEthernet0/0
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 65.65.128.193 255.255.255.224
shutdown
duplex auto
speed auto
interface Serial0/2/0
ip address 65.65.13.2 255.255.255.224
encapsulation ppp
clock rate 2000000
interface Serial0/3/0
no ip address
shutdown
router ospf 65
router-id 65.65.2.2
log-adjacency-changes
network 65.65.2.2 0.0.0.0 area 1
network 65.65.13.2 0.0.0.0 area 1
network 65.65.128.193 0.0.0.0 area 1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip sla 1
frequency 10
control-plane
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
R2#
R2#
Joe Clarke Tue, 07/13/2010 - 21:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The command "snmp-server host 150.150.1.1 public" is causing the traps to be sent, but they must be enabled.  Given this config, I would think a reload would mean traps would no longer be sent.  Typically, one would do:
snmp-server host x.x.x.x traps public
Lokesh.Khanna Wed, 07/14/2010 - 12:55
HI
is it possible that the word "trapOnly" in "ip sla reaction-configuration 1 react rtt threshold-value 5 1 threshold-type immediate action-type trapOnly"
causing snmp trap to get generated.
I have rebooted router and i only have snmp-server host xxx public on my router defined and still i see traps going out.
Joe Clarke Thu, 07/15/2010 - 19:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It is certainly possible, but I have not seen this behavior in the past.  This may be a bug.  I tested locally on a switch in my lab, and I cannot recreate, but I do not have your show ver.  I recommend you open a TAC service request if you want to pursue this further.
