NDG Application in TACACS+
Jul 11th, 2010
hi,
i am trying to get around 900 cisco routers authenticated through Cisco TACACS+ ,while doing this i added two clients and two users corrosponding to them,i hav two issues
1# if there is a user and a group each needed for each client if we add them individually.(i.e. 900 users and groups) ?
2 #I plan to group all my devices ,so i plan to form a NDG,i have prepared three shell command authorization sets and three users in three separate groups,
each user has different commands execution permission,can i use all three users on same NDG?(to acess all clients in the NDG with different privileges.
Kindly let me know if i m thinking on right lines and Is there any other way to administer such large no. of clients.
Kindly help,
Thanks.
Ganesh Hariharan Mon, 07/12/2010 - 02:30
hi,
Kindly help,
Thanks.
Hi Anu,
If you want to filter based on user for certain aaa clients then best is to have user based restriction on user profile and if user and group both need access to same client then it will best to restrci on group only is enough and assign those users to the same group in which you have applied.
Better to use users based on privillage level on different aaa clients rather on common group.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
