How to configure "view-only" priviliges on Catalyst Device Manager
Jul 12th, 2010
a customer want a user which has view-only rights on his catalyst switches. I created a user whit privilige level 7.
If you log into the CLI everything is fine. But by trying to log into the web page the system wants a level 15 user.
Is their any possibility to grant the level 7 user "view-only" rights on the Catalyst Device Manager?
Thanks.
Thanks.
Ganesh Hariharan Mon, 07/12/2010 - 02:16
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Thanks.
Thanks.
Check out the below link for SDM for read only user configuration
http://conft.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/application/notes/SDMcli.pdf
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
dschmitz87 Mon, 07/12/2010 - 02:25
Unfortunantly I don't have a router. The customer has catalyst switches and they only have the catalyst device manager not the SDM.
dschmitz87 Tue, 07/13/2010 - 00:06
Thanks for your hint. But the problem is that I don't now which comannd I have to use, to get the web-view working.
