CUPS 7.0.8 with Communicationsmanger 6.1.4 or 7.1 Deskphone Troubles
Jul 12th, 2010
Hy Out There,
we have got an CuCM Cluster with LDAP Authentication over SSL.
All is working fine beside the CUPS Deskphone or the Sametime Plugin Deskphone Control.
I've read this article
http://htluo.blogspot.com/2009/01/myterious-invalid-crdential-on-cupc.html
but we are not able to change the tcp port for authenticate, because of some security things.
Is there another Workaround or ist there a fix within Communicationsmanger
thnxs for your Replies
cheers Floh
Aaron Harrison Mon, 07/12/2010 - 02:46
  • Community Spotlight Award,
    Member's Choice, May 2015
If you can't repoint to the global catalog port (that's a very common solution) then you would need to try to work out where the delays are coming from that are causing the authentication to time out.
Best way to do this is to run a packet capture on the CCMs to see the LDAP traffic, and then go through it looking for failures or delays in response. Based on that you'll likely need to resolve some directory issues - such as bad DNS entries, slow responding servers, incorrect AD sites config, etc..
Aaron
Florian Kroessbacher Mon, 07/12/2010 - 03:00
Hy Aron!
now we have got a Test with the normal LDAP Port 389, and everything is good!
I think there is a Problem with the CTIManager interact with SSL
How can a debug this thing
cheers Floh
Aaron Harrison Mon, 07/12/2010 - 03:05
You may find that it works intermittently; depending on where the connection is sent, what replies come from DNS, etc etc...
If so, best way to troubleshoot I find is using a packet capture as suggested above.
Aaron
