Router 2801 Error show flash
Answered Question
Jul 12th, 2010
On my 2801 I've got thi issue:
2801Voice_Gateway_MI#show flash:
%Error show flash: (No device available)
2801Voice_Gateway_MI#show version
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 12.4(6)T7, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 29-Mar-07 05:41 by khuie
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
2801Voice_Gateway_MI uptime is 46 weeks, 1 hour, 18 minutes
System restarted at 09:38:26 CEST Mon Aug 24 2009
System image file is "flash:c2801-spservicesk9-mz.124-6.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2801 (revision 4.1) with 235520K/26624K bytes of memory.
Processor board ID FCZ091622WG
2 FastEthernet interfaces
4 ISDN Basic Rate interfaces
1 DSP, 8 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
Can you help me?
Correct Answer by Leo Laohoo about 6 years 11 months ago
You sure the CF wasn't ejected by accident?  Uptime of 46 weeks.  Either the CF is faulty, the CF slot is faulty or someone pulling a prank and the CF was ejected.  Manual intervention is the way to go.
Overall Rating: 5 (1 ratings)
wang baojun Mon, 07/12/2010 - 02:17
hello ,
the problem seem happen like in simulation dynamic router , the real router ,i have no idea . you can try reboot the C2801.
or the flash card was broken .maybe.
SHF#show flash
System flash directory:
File  Length   Name/status
  1   15194664  c2600-ik9o3s3-mz.122-15.T12.bin
[15194728 bytes used, 1058200 available, 16252928 total]
16384K bytes of processor board System flash (Read/Write)
SHF#show flash
  1   15194664  c2600-ik9o3s3-mz.122-15.T12.bin [deleted]
SHF#squeeze flash:
Squeeze operation may take a while. Continue? [confirm]
squeeze in progress... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Squeeze of flash complete
SHF#show flash
No files in System flash
[0 bytes used, 16252928 available, 16252928 total]
Nagaraja Thanthry Mon, 07/12/2010 - 05:53
  • Cisco Employee,
From the show version output, it seems like the flash card is not recognized by the hardware. Most likely it is a bad flash card issue or it could be a bad slot on the router as well. If you have a spare flash (know to be good) card, please try it on the router. If that is also not recognized, I would suspect the router itselve. You might have to get the router replaced.
Hope this helps.
NT
Correct Answer
Leo Laohoo Mon, 07/12/2010 - 15:18
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
bagnolini Mon, 07/19/2010 - 06:40
I've changed the flash and now evwrything is ok
thanks
