Application connection Issue
Jul 12th, 2010
Financial module service is outsourced in the organization
Customized application installed on LAN workstation needs port 9090,9091,9092 to be opened to reach
Financial Module Server hosted on Internet.
FMS_Server----{Internet}------((R))----Firewall----((Core))------LAN
        Proxy
Default_Gateway for Core is Firewall
Users default_Gateway is Core
Users IE is configured with Proxy_Server
Application doesnt uses IE settings ( no option in application to put proxy )
Firewall got ACL_Inside and ACL_Outside
On ACL_inside all IP is allowed to communicate with port 9090,9091,9092  but Application cannot connect to the
It only works when I  do a static NAT with Public IP
Any Help
Hitesh Vinzoda Mon, 07/12/2010 - 02:12
  • Silver, 250 points or more
When you are travelling from Higher to lower security level you need to have NAT enabled. It could be Static NAT or PAT.
Hitesh Vinzoda
Pls rate useful posts
saquib.tandel Mon, 07/12/2010 - 02:56
When someone from outside needs to reach inside he too needs a NAT
( example is publishing a website )
if above is true then whts the difference.
How can I make it work with PAT
( If I got a DSL connection then the Financial Module application connects like a champion, DSL is without regular static IP )
