Back-up Route.
Answered Question
Jul 12th, 2010
Hi ,
I have a scenarion ,    R1------R2---( private cloud)----R3------R4
Description ---  1)R1,R2  are at one site , R2 connects to private cloud.
                        2)  R3,R4 are at another site , R3 connects to private cloud.
                         3)  R1 n R4 have back-up secondary high cost link connection.
Query -- R1 has default route towards R2 ( for internet and all destination of R4(site 2)) ,  also R1 have wireless slow link with R4.
             i dont have access to R2. how can i route traffic for Site 2 destinations on R1 via wireless link If R2 losses its connection to cloud.
            NOTE - i dont have access to R2 and there is no dynamic protocol running.
Thanks in Advance,
Mazhar.
Correct Answer by saquib.tandel about 6 years 11 months ago
I got a question.
How does it work when a routing protocol is applied between R1--to---R2 and R1---to---R4
example Eigrp and OSPFas Routing Protocol...
Correct Answer by wang baojun about 6 years 11 months ago
hello ,
we can use cisco ip sla technology.  use route track feature.
reference to , http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst4500/12.2/44sg/configuration/guide/swipsla.html
ip sla 1
ip route 0.0.0.0 0.0.0.0 R2-IP track 10
ip route 0.0.0.0 0.0.0.0 R4-IP 111 track 20
when track 10 down, the route "ip route 0.0.0.0 0.0.0.0 R2-IP" will disappear in route table ,they the route "ip route 0.0.0.0 0.0.0.0 R4-IP" install .
Overall Rating: 5 (2 ratings)
Correct Answer
wang baojun Mon, 07/12/2010 - 02:53
hello ,
ip sla 1
Correct Answer
saquib.tandel Mon, 07/12/2010 - 03:00
I got a question.
mazhar mahadik Mon, 07/12/2010 - 04:10
CASE 1 -   If same routing protocol is running between all routers then no further tracking is required, protocol will take care of convergence.
CASE 2 - If routing protocol is running only btwn R1--R2 , R3--R4 , and R2 is not advertizing R4 destinations to R1 then similar tracking suggested by wang is required.
Hope i m not confusing.
Mazhar
mazhar mahadik Mon, 07/12/2010 - 03:17
Hey thanks wang for your reply,
u mean i shld track the ip sla n if sla is down thru R2 then it will install higher admin distance R4 route.
let me try this n come back to you.
mazhar mahadik Tue, 07/13/2010 - 01:07
Hey thanks wang ,
i tryied it n it works, this is a smart solution, thanks for your help.
Mazhar.
