http filter use QOS
Jul 12th, 2010
my config like this:
Class Map match-all 1 (id 3)
   Match protocol dns
Class Map match-all 2 (id 4)
   Match protocol http host "**"
Class Map match-all 3 (id 5)
   Match not class-map 1
   Match not class-map 2
Policy Map 1
   Class 1
   Class 2
   Class 3
I want deny all web access except to
If i not use "drop" command in class 3,i can see packets match stats in class 2 when i use command "show policy-map interface";but if i use "drop" command in class 3,all http packets will be droped,i can't access the,and there is any packets match stats in class 2,but class 1 and class 3's match stats grow up correct,i try some other way for class 3,like:
class 3
    match class class-default
class 3
    match any
class 3
    match access-group xxx
but all fail,the router drop all http packets as long as "drop" command be used in class3.
please help me,thx
flowaycco Mon, 07/12/2010 - 06:21
Thx very much!
But my equipment is 2921 router,not firewell,and only ip base ios,so i must use qos to do this only.:(
