Ganesh Hariharan Mon, 07/12/2010 - 04:12
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi All,
Is it possible that the firewall will be your gateway but you have inter vlan routing as well?
How will i configure the L3 switch to do that situation?
If you are doing intervlan routing first and then firewall is coming into picture better recommednation is to have the gateway as svi of the vlan configured in switch and if you want firewall to be the gateway for the user make firewall ports to be the member of those vlans and then configure gateway for each users in vlan to be firewall.
http://cisco.biz/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
nelba_aldovino Mon, 07/12/2010 - 17:34
Hi All,
but in my situation firewall first before the L3  switch.
Is it possible that the firewall will be the gateway for  that situation?
My L3 switch will be the cisco catalyst 3750.
Nagaraja Thanthry Mon, 07/12/2010 - 17:45
  • Cisco Employee,
If the firewall is connected to internet and you want all the internet traffic to reach the firewall, the better way is to configure the switch as the default gateway and on the switch, configure firewall as default gateway. But if the firewall is sitting right in-between the VLANs i.e.one interface of the firewall is in one VLAN and the other on the second VLAN and you would like all traffic between those VLANs to go through the firewall, then, turn off the layer 3 interface for one of the VLANs and make the firewall as the default gateway for that VLAN.
Hope this helps.
NT
nelba_aldovino Mon, 07/12/2010 - 17:56
How will i do that?
My firewall will be connceted to the internet.
Your first line of words fit to what i'am planning to make.
See below for your reference
nelba_aldovino Mon, 07/12/2010 - 18:01
Another thing, I will be using ACL on layer 3 instead of inter vlan routing.
Nagaraja Thanthry Mon, 07/12/2010 - 18:08
  • Cisco Employee,
In your case, making L3 switch as the default gateway for all VLANs will be the best way. In this way, all traffic destined to local LAN will be handled by the switch and only the internet traffic will go to the firewall. If you want other VLANs also to access internet, you can do that with this implementation. Make sure that your default gateway on the switch is pointing to the firewall.
ip route 0.0.0.0 0.0.0.0
If you want VLAN 3 and VLAN 4 to access internet via the firewall, then on the firewall, have static routes configured for those subnets.
route inside
route inside
Hope this helps.
NT
nelba_aldovino Mon, 07/12/2010 - 18:20
Hi Nagaraja Thanthry,
Can you give me example on how will i do vlan 3 and vlan 4 to access internet via the firewall?
for example:
vlan 2 ip = 192.168.1.1/24
vlan 3 ip = 192.168.2.1/24
vlan 4 ip = 192.168.3.1/24
so i will do this command on my firewall:
for vlan 3:
route inside 255.255.255.0 192.168.1.1
for vlan 4:
am i right?
thank you!
Ganesh Hariharan Mon, 07/12/2010 - 23:15
for example:
for vlan 3:
for vlan 4:
am i right?
thank you!
Create a NAT rule in firewall for vlan subnet and then try to access the inetrnet from specified vlans.
https://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008046f31a.shtml#s11
Hope to Help !!
Ganesh.H
its very easy ,
L3 confugration :
ip routing
inter vlan 2
ip helper-address { DHCP ip address } if you use DHCP
inter vlan 3
ip address 192.168.2.1 255.255.255.0
inter vlan 4
ip address 192.168.3.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 { Fierwall IP address }
do trunk beteween any to switches
know all all vlans can comencate withe eache other and internet work fine
the defualt gateway for users is the same IP for vlan interface in L3 Switch
the defualt route meen any packet withe known distenation (internet) will send it to Fierwall
nelba_aldovino Tue, 07/13/2010 - 01:15
what if not all member of that vlan will be given internet connection?
Only choosen person will be given conncetion to the net.
will it be possible?
And not all vlan required to communicate with each other.
here is the situation to clarify my problem.
Catalyst 3750 consist of ACL and inter vlan routing
what if i want one of the pc in vlan 3 to have internet connection and the rest will not have net connection?
how will i configure it?
nelba_aldovino Tue, 07/13/2010 - 17:57
We need ACL because it is not required that all vlan should see each other.
But All vlan should see the servers or the vlan 2 in the figure.
And vlan 2 should see all the vlan (vlan 3 and 4)
Vlan 3 and 4 should not see ech other.
Only selected users in vlan 3 and 4 will be given access to the net.
Our firewall is ASA 5510
Nagaraja Thanthry Tue, 07/13/2010 - 18:11
  • Cisco Employee,
In that case, you need to play around with the access-lists:
On the firewall:
route inside 192.168.2.0 255.255.255.0 192.168.2.1
route inside 192.168.3.0 255.255.255.0 192.168.2.1
global (outside) 1 interface
nat (inside) 1 192.168.2.0 255.255.255.0
nat (inside) 1 192.168.3.0 255.255.255.0
On the Switch:
ip routing
ip route 0.0.0.0 0.0.0.0 192.168.1.2 (Firewalls IP)
access-list 103 permit ip host
ip access-group 102 in
exit
Hope this helps.
NT
Nagaraja Thanthry Tue, 07/13/2010 - 07:15
  • Cisco Employee,
In order to allow certain hosts from VLAN3/4 to access internet via the firewall, please try the following configuration:
On the firewall:
route inside 192.168.4.0 255.255.255.0 192.168.2.1
nat (inside) 1 192.168.4.0 255.255.255.0
On the Switch:
ip routing
ip route 0.0.0.0 0.0.0.0 192.168.2.2 (Firewalls IP)
access-list 103 permit ip host any
access-list 103 permit ip any 192.168.0.0 0.0.255.255
access-list 103 deny ip any any
access-list 104 permit ip host any
access-list 104 permit ip any 192.168.0.0 0.0.255.255
access-list 104 deny ip any any
interface VLAN 3
ip access-group 103 in
exit
interface VLAN 4
ip access-group 104 in
exit
In the above example, the firewall is allowing only certain hosts (IP1, IP2) to access internet and everybody else is blocked from internet access. You can add additional lines as necessary.
Hope this helps.
NT
nelba_aldovino Tue, 07/13/2010 - 19:00
Hi All,
I'll try all your recommendations.
Just another question, do you know any software that i may use to
try the configuration and connection of my figure.
Since packet tracer has no ASA devices only switches, routers, hubs, etc.
There is no ASA or other firewall devices.
thank you so much to all.
Nagaraja Thanthry Wed, 07/14/2010 - 18:02
  • Cisco Employee,
Glad that we could help. If your issues are addressed, can you please mark the question as answered in the forum so that other users can use it.
NT
