CME and CUCM- questions
Jul 12th, 2010
Dears,
Q1- how can i disable web access to ip phones in CME environment: C3825-SPSERVICESK9-M), Version 12.4(24)T1
i configured on telephony service and also under ephone-template :service phone webAccess 1 but useless.
is there any solution for that ? i reset the phone many time after appling it on telephony service and template.
Q2- in CUCM version 6.x: can i disable Mute button on agent ip phones . this is requested by customer in UCCE environemnt ?
thanks and regards
david-lima Mon, 07/12/2010 - 07:04
  • Bronze, 100 points or more
Hi, this works for me:
    telephony-service
           create cnf-files
           reset all
hth
David
valiegenus Mon, 07/12/2010 - 22:33
thank you , it worked after i reload the CME , i applied all the step you sent before but failed .
anyway thank pou very much ,what about Mute button is there any way to remove it.
regards
