cucm 7.1.2 + no external call forward all from phone
Jul 12th, 2010
hi @ all,
i use cucm 7.1.2 with 2801-router as h323-gateway. everything is fine but if i want to configure a external cfwall on the phone i can only dial 2 digits. so only a 2-digit-number is configured. i cant dial more digits. internal everything is ok. does anybody know the problem? our internal dn are 100-299. my outbound route pattern is 0.!
rob.huffman Mon, 07/12/2010 - 07:34
Hi There,
Check the Call Forward All CSS (Calling Search Space) on the Directory Number config page. Ensure that the Call Forward All CSS has access to External Calling CSS.
Hope this helps!
Rob
iptuser55 Mon, 07/12/2010 - 09:07
Also to add check what the setting is for the Call Forward
  • With Configured CSS- it uses the two CSS you have against Forward All and Secondary - same as a phone, DN
  • With Activating Device./ Line - it uses the CSS of the Line and Device
  • With system - Uses the System parms
The difference with Activating and Configured,  is that with Configured you can allow a user to dial International , Premium rate numbers but block call forward all to these same numbers- Toll Fraud but  with Activating- the call block for handset dialing and call forward all are the same
hope it helps
COMMpact001 Tue, 07/13/2010 - 01:32
hi @ all,
i checked my configuration under the dn. i dont configured any css for cfwall. "Calling Search Space Activation Policy" is configured to "Use System Default" and on "Forward All" "none" is configured unter css. do i need such a css. i can call out without any problems but cfwall does not work - only internal.
all my phones are in the default partition.
Jaime Valencia Tue, 07/13/2010 - 06:44
Yes, you need. You just explained why this doesn't work but it appears you don't understand why.
Read this so you can understand CSS and partitions
Calling Privileges in Unified CM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/dialplan.html#wp1044276
And you should stay away from avoiding partitions and leaving everything in the default partition, that will only cause trouble in the future.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
COMMpact001 Tue, 07/13/2010 - 07:24
ok i will read this and i will try configure partitions. i will answer after that.
COMMpact001 Wed, 07/14/2010 - 02:25
hi javalenc,
i did what you said. i created a partition and put all my dns, voiceports, transformation-pattern and external route pattern into it. . further more a created a css that include my partition. on the dn(s) i set
Calling Search Space Activation Policy     -> use system default
Forward All                                             -> the css that include my pstn route pattern.
but if i try to set a cfwdall on the phone i the dialing breaks after 2 digits so that only 2 digit are configured for cfwdall.
my route pattern is 0.!
whats now?
COMMpact001 Thu, 07/22/2010 - 23:06
hi,
i managed to solve the problemwith the help of tac. the problem was the option "urgent priority" at the route pattern connfiguration.
thanks all for helping.
