Help ASA and AUS
Jul 12th, 2010
i installed last week CSM 4.0 and AUS 4.0 in a customer CED.
I need to backup the ASA config (running or start-up) to AUS every day.
Is possibile ?
If yes can some on help me?
Thanks a lot best regards.
Ganesh Hariharan Mon, 07/12/2010 - 23:48
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Is possibile ?
I don't think it is possible because Auto Update is a protocol specification that allows an Auto Update server to download configurations and software images to many security appliances, and can provide basic monitoring of the security appliances from a central location. The security appliance can be configured as either a client or a server. As an Auto Update client, it periodically polls the Auto Update server for updates to software images and configuration files. As an Auto Update server, it issues updates for security appliances configured as Auto Update clients.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/mswlicfg.html#wp1060073
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
