Call on the same Cluster between two phones failed
Jul 12th, 2010
I have a small cluster with 2 Servers one server is acting as subscriber and publisher and the other server is only acting as a subscriber.
If i register a phone to the publisher/subscriber and another phone to the subscriber i could make calls to outside an from outside to inside.
But a call internal from one to the other phone don`t work i get a fastbusy, is anyone can help me wehre the problem could be ?
Version: 4.2.3b
Best Regards,
Martin
David Hailey Mon, 07/12/2010 - 09:20
  • Purple, 4500 points or more
First thing you need to check is the CSS on the phone.  You need to have the Partition(s) that the directory numbers on the phones are in included in the CSS that is assigned to the phone(s).  Just because 2 phones have numbers in the same partition does not mean they can call each other.  The CSS must be configured to allow internal dialing as well.
Hailey
Please rate helpful posts!
gariusmar Mon, 07/12/2010 - 10:27
Hi Hailey,
Thanks for your answer, the phones are in the same css that`s the strange thing.
Martin
gariusmar Mon, 07/12/2010 - 10:28
When the phones are registered on the same server it`s working all fine.
David Hailey Mon, 07/12/2010 - 10:31
Ok. Have you checked DB replication within the cluster? Sounds like you may have an issue there.
gariusmar Mon, 07/12/2010 - 10:54
I thinks that looks good maybe i hav to do an reinitialize or republish of the databas>> waht do you mean...
Jaime Valencia Mon, 07/12/2010 - 11:21
  • Cisco Employee,
  • Hall of Fame,
    2011
SDL layer is in charge of calls when they are between servers, you might want to do a cluster reboot to sync the SDL layer
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
