What "request method get url" does ?
Answered Question
Jul 12th, 2010
i have a ACE lb and i´d like to configure request method get url but i´m not sure what are the expected result and i couldn´t found any information on cisco.com.
Correct Answer by UHansen1976 about 6 years 8 months ago
Try'n have a look at this, I think you will find it useful.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA2_3_0/configuration/slb/guide/probe.html#wpxref46342
But in short, when applying e.g an http-probe to your serverfarm, you can specify a request method (GET og HEAD) to request specific content from the rserver using http. Combined with either http response-code check or regex, this provides for more detailed availibility information on the specific rserver.
hth
/Ulrich
Overall Rating: 5 (1 ratings)
Correct Answer
UHansen1976 Mon, 07/12/2010 - 11:52
  • Bronze, 100 points or more
hth
/Ulrich
perpignanetworking Mon, 07/12/2010 - 12:08
Great, thanks. It seems this configure the HTTP probe to use the http request method (get) instead of TCP. Thank you.
