CUCIMOC implementation
Jul 12th, 2010
Please let me know how to inplement CUCIMOC with following devices:-
  • CUCM 7.0
  • OCS 2007 R2
What configuration will be required ? How many license will be consumed by CUCIMOC ?
Abhas Jain
htluo Mon, 07/12/2010 - 10:19
  • Red, 2250 points or more
1. CUCIMOC installation file is required.
2. No license will be consumed if you don't use soft phone mode.
Michael
http://htluo.blogspot.com
robray_sc Fri, 07/23/2010 - 14:05
If its CUCM 8.0 and you want to use the softphone which license(s) is needed? Do I only need the LIC-ADJ-USR-AUDVID or is it something else.
If I only want to use the CUCIMOC for presense and IM then no license is needed on the CM side?
htluo Fri, 07/23/2010 - 15:26
There's no such thing called "use the CUCIMOC for presense and IM".
Presence and IM was provided by MOC (Microsoft).  They have nothing to do with CUCIMOC (Cisco).
Michael
yshraybman Thu, 09/09/2010 - 13:35
  • Bronze, 100 points or more
So if I want to pass only phone status to MOC and not do any dialing, would I still need to use Cisco Unified Client Services Framework and consume 3 DLUs?
matthewtravers Tue, 10/12/2010 - 17:02
Hi yshraybman,
It is my understanding that, should you wish to use CUCiMOC only for Remote Call Control and to pass presence into CUCM, you do not require any licensing on CUCM.
However, if you wish to use the soft phone feature of CUCiMOC, you would require the appropriate Adjunct device UCL (or equivalent CUWL).
Cheers,
Matt
Related Content
