Session ID
As part of a project we have going on, I am attempting to extract the session ID from a phone call and store it in a variable.  What I have done is use a "Get Contact Info" step and using the "Session" field.  However, the info I'm getting from this field does not match the SessionID field of the ContactCallDetail table of the database.  What is the Session field under the Get Contact Info step really giving me?
Tanner Ezell Mon, 07/12/2010 - 12:41
  • Silver, 250 points or more
I have attached (assuming the web-reply feature allows it) a document
I created that covers your issue. Specifically of value to you:
assume you store your session information into a string called SessionID
int.valueOf(SessionID.toString().subString(17,25), 16)
Which will extract the hexadecimal session id and convert it into base 10.
Cheers,
Tanner Ezell
On Mon, Jul 12, 2010 at 1:56 PM, [email protected]
Aaron Harrison Tue, 07/13/2010 - 14:25
  • Community Spotlight Award,
    Member's Choice, May 2015
It's substring, not subString - java is all case sensitive.
Aaron
Tanner Ezell Mon, 07/12/2010 - 12:42
My apologies, a Session variable named SessionID, not String.
Tanner Ezell Tue, 05/21/2013 - 08:22
Yes, this seems to have changed since the posting.
You can more accurately get the SessionId by capturing the "Session" from Get Contact Info Step, and then pulling the "Identifier" from Get Session Info Step.
Tanner
