david-lima Mon, 07/12/2010 - 12:03
  • Bronze, 100 points or more
Hi, the IP Phone 7911 does not support speaker function.
hth
David
Afragoso2009 Mon, 07/12/2010 - 15:49
HI David
The SPEAK works normaly
The microfone doest work on the 7911
I was able tp use the internal SPEAKER on it , but suduntly it stop
paolo bevilacqua Mon, 07/12/2010 - 19:13
  • Hall of Fame,
    Founding Member
David is correct, since the 791x do not have a microphone, there is no handsfree or speakerphone feature, consequently the only way to answer calls, is picking up the handset.
Afragoso2009 Tue, 07/13/2010 - 12:17
Its a CISCO 7911G
I had already use this feature on this fone on CCME ver 7 an CCM ver 4
