CUCM 7.1.3 and VG-224 installation
Answered Question
Jul 12th, 2010
I cannot seem to get my new VG-224 to register to CM.  Setting the VG-224 up as SCCP- I built the gateway in CM and configured the VG-224.  I can ping the IP address of the VG-224 but it does not register to CM.  Can post the VG-224 config if needed.
Any thoughts or direction?
Overall Rating: 5 (4 ratings)
Adrian Saavedra Mon, 07/12/2010 - 15:11
  • Gold, 750 points or more
If configuration is 100% correct (CM and VG224), you can try:
vg224(config)#no sccp
vg224(config)#sccp
vg224(config)#no stcapp
vg224(config)#stcapp
Hope it helps, please rate if it does.
Kind regards,
- Adrian.
Correct Answer
William Bell Mon, 07/12/2010 - 15:38
  • Purple, 4500 points or more
Les Pruden Tue, 07/13/2010 - 07:23
Thanks for getting back to me -
Turned out that I missed the stcapp command after the command stcapp ccm-group 1
stcapp ccm-group 1
stcapp  <------------missed this
So - I didn't have the VG-224 programed correctly after all.  Once I entered that the Vg-224 registered right away.
Les
