NLB Issue
Jul 12th, 2010
Dear All,
            The IP addresses 10.134.189.12 and 10.134.189.13 are server physical ip's. the cluster ip for these servers is 10.134.189.50. all these servers connected to cisco linksys switch1 and linksys switch2. linksys1 connected to Cisco6513 switch 1, linksys2 connected to cisco6513 switch 2 for redundancy. HSRP is configured.
            The problem is i cannot ping cluster ip  from outside subnet, and even i cannot ping from Core switch itself, But, if i ping any one physical ip from outside subnet, then i can ping cluster ip.
          Even the outside subnet users can able to ping (after pinging physical ip), but still the core switch cannot ping cluster. but the path from outside users going via Core switch only.
           I entered the static entry for arp as #arp 10.134.189.50  00bd.00af.bf32 arpa (alias)
server1:
ip-10.134.189.12
subnet /25                        Linksys1                               Core C6513 Sw1
def gw-10.134.189.126----->ip10.134.189.122/25    --------->vlan 5- ip 10.134.189.25/25
Cluster ip 10.134.189.50    def gw 10.134.189.126            Def gw-10.134.189.126 (HSRP)
server2:        |
ip-10.134.189.13               Linksys2                             Core C6513 Sw2
subnet /25              -------->ip10.134.189.123       -------->vlan 5- ip 10.134.189.30/25
def gw-10.134.189.126       def gw 10.134.189.126         Def gw-10.134.189.126 (HSRP)
Thanqs in advance
