Help with IP phone upgrade
Jul 12th, 2010
I have a cisco Call manager express 2821. Show Telephony-service command shows it as version 4.1(0).
I have a cisco 7975 Phone which is running SCCP 8.3.2 version, recently i have tried to attache a operator console 7916-12 to it, but Phone wont recognise it, a google search confirmed that it needs to be updated to SCCP version 8.3.5.
I have logged into download and saw three options. One is .sbn Second is .exe and Third is .zip.
I need some body to explain me how do i diffrentiate between call manager and call manager express. both seem to be having version 4.x and 7.x ?
What is  Cisco Unified Call Manager ( is this call manager based on windows or Linux platforms)?
How do i differntiate between call manager and call manager express with version numbers?
Your help will be appreciated.
Thanks in advance
Overall Rating: 4.5 (2 ratings)
paolo bevilacqua Mon, 07/12/2010 - 14:04
  • Hall of Fame,
    Founding Member
Use zip, extract and copy to router, configure load with .load extension, configure cnf-location flash: that's it.
Cisco recommend 8.4(4), I run 8.4.4.
Asim ali Mon, 07/12/2010 - 14:28
Hello
Thank you for your reply, that was very quick.
I have done the same with the version which i have, i have already downloaded 8.4.1 .zip. Followed all the steps. But phone still loads the old version which is 8.3.2. below is the debug tftp events output.
Jul 13 00:20:28.130: TFTP: Looking for CTLSEP64168D511CCF.tlv
Jul 13 00:20:28.206: TFTP: Looking for SEP64168D511CCF.cnf.xml
Jul 13 00:20:28.206: TFTP: Opened flash:/its/vrf1/XMLDefault7975.cnf.xml, fd 14,
size 1201 for process 289
Jul 13 00:20:28.226: TFTP: Finished flash:/its/vrf1/XMLDefault7975.cnf.xml, time
00:00:00 for process 289
Jul 13 00:20:35.010: TFTP: Looking for SCCP75.8-4-1SR2S.loads
Jul 13 00:20:51.638: TFTP: Looking for CTLSEP64168D511CCF.tlv
Jul 13 00:20:51.846: TFTP: Looking for SEP64168D511CCF.cnf.xml
Jul 13 00:20:51.846: TFTP: Opened flash:/its/vrf1/XMLDefault7975.cnf.xml, fd 14,
Jul 13 00:20:51.850: TFTP: Finished flash:/its/vrf1/XMLDefault7975.cnf.xml, time
Jul 13 00:20:53.154: TFTP: Looking for English_United_States/td-sccp.jar
Jul 13 00:20:53.430: TFTP: Looking for United_States/g3-tones.xml
Jul 13 00:20:53.886: %IPPHONE-6-REG_ALARM: 25: Name=SEP64168D511CCF Load= SCCP75
.8-3-3SR2S Last=Initialized
Jul 13 00:20:53.906: %IPPHONE-6-REGISTER: ephone-3:SEP64168D511CCF IP:192.168.0.
7 Socket:3 DeviceType:Phone has registered.
I have already applied the command and i could see the same in sh telephony-register.
load 7975 SCCP75.8-4-1SR2S
In show flash also i could see all files ?
is there a upgrade path? Or am missing something ?
Thank YOU
Asim ali Tue, 07/13/2010 - 00:36
Found a great doc on the confusion may be it will be helpfull to other here.
https://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
btw i was able to upgrade the firmware, cnf file location command was the one which i was missing probably, also the extension .load after the file name in telephony service. Phone registered with new firmware.
Now the task is to get this 7915-12 console running.
will update you in few hours..
Thank YOU
Asim ali Tue, 07/13/2010 - 05:39
This module is giving me hard time.
I have upgraded phone(7975) to version 8.4, and i have issues the load (B016-1-0-2SR1.SBN) for 7916-12.
But i still see the module in stable amber color.
In telephony service i have below.
load 7916-12 B016-1-0-2SR1.SBN
load 7975 SCCP75.8-4-4S
But still the module wont registers, it shows in Phone > status = not configured
the tftp output wont show anything except 7975 registration.
" ul 13 15:36:22.695: %IPPHONE-6-REG_ALARM: 22: Name=SEP64168D511CCF Load= SCCP75
.8-4-4S Last=Reset-Reset
Jul 13 15:36:22.731: %IPPHONE-6-REGISTER: ephone-2:SEP64168D511CCF IP:192.168.0.
2 Socket:2 DeviceType:Phone has registered."
I dont see even attempts of loading B016-1-0-2SR1.SBN, eventhough the command is there in telephony service with file in flash.
Any ideas ....
Plzz
