VPN
Cisco CyberSecurity
Labels
Hello,FTD's 2110 at 7.3.1.1.I have two datacenters running that code on 2110s. They have the same configuration for the most part and the same size fiber internet 500 Mbps circuit. Coming in on VPN1, running a speed test from my home connection is ab...
dcanady55 by Level 1
  • 103 Views
  • 6 replies
Hi,I have a newly reinstalled OS Windows 11 PC. There is Cisco AnyConnect Secure Mobility Client on my PC to connect to my work access. Randomly my pc crashes, basically freezes. After manually power off and power on When I check event viewer the las...
Hi, I have one issue with IPSec tunnel Lan-to-Lan between ASA 5525x (v9.8) and ASA FPR 2110 (v9.16). My Tunnel is up but ping between each client was not successful. Both peer status sh cry isakmp sa in "MM_ACTIVE".I ran packet-tracer icmp between pe...
El Rondo by Level 1
  • 508 Views
  • 24 replies
After starting anyconnect I find network connectivity stops working under WSL2 (Windows Substem for Linux)the fix seems to be: Get-NetAdapter | Where-Object {$_.InterfaceDescription -Match "Cisco AnyConnect"} | Set-NetIPInterface -InterfaceMetric 400...
Hello, as part of my preparation for CCNA Security I've been making up my own topologies and configuring them, however, I need a little help with this one. In the topology (included .pka), I configured VLANs, Port Security, OSPF, OSPF Authentication ...
xmorav45 by Level 1
  • 104 Views
  • 0 replies
Hi EveryoneI'm using a trial version of ASAv and i believe it has full functionality but is limited in 100kbps. I'm trying to set up remote access anyconnect vpn which authenticates to our NPS radius server. As you can see in the radius debug, it see...
When a client connect to the HQ via AnyConnect vpn, they can access the HQ local subnet, but can´t access the subnet at the remote office, that has an site-to-site connection to the HQ.Can this be configuret via the Cisco Firepower gui?Cisco Firepowe...
Hello everyone,Can you provide me with the eventid of the VPN failed logon on Cisco's devices?I couldn't find any examples and i wan't to create a brute force rule for it in my SIEM solutions.
CMPC by Level 1
  • 115 Views
  • 1 replies
