Cisco 1522 Mesh AP as a Bridge
michaelgitonga
Can I use two Cisco 1522AG access points as a bridge? - just as the way two 1300 series or 1400 series APs would be used.
For example one 1522 AP as a RAP and the other as a MAP whereby the MAP is connected to a LAN that is to be bridged....is this possible and if it is, what ports do I used to connect to the bridged LAN - 'PoE In' or 'PoE Out'?
Vinay Sharma
Level 7
Level 7
Are you still facing this issue?
thanks,
Vinay
Thanks & Regards
