how can configure VPN client with LDAP?
Answered Question
Jul 12th, 2010
Dear All,,
How can configure VPN client with LDAP on Cisco router and ASA?
i have Cisco router 1841, and ASA 5505.
Best Regards
Rechard_David
Correct Answer by Nagaraja Thanthry about 7 years 1 week ago
Here is a sample configuration for the firewall (ASA):
aaa-server TEST protocol nt
aaa-server TEST (inside) host 192.168.254.11
nt-auth-domain-controller Primary
nt-auth-domain-controller Cisco
tunnel-group VPNGR type ipsec-ra
tunnel-group VPNGR general-attributes
address-pool VPNPool
authentication-server-group TEST LOCAL
default-group-policy VPNGR
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Correct Answer
Nagaraja Thanthry Mon, 07/12/2010 - 20:34
  • Cisco Employee,
Hope this helps.
NT
rechard_david Tue, 07/13/2010 - 19:25
Dear NT,
Thanks you for your assist!!!
Could you let me know , How can we configure VPN with LDAP on Cisco Router? Remote acces, not SSL
Best Regards,
Rechard_david
rechard_david Thu, 07/15/2010 - 03:40
Dear NT,
Thank you for your help!!!
I was rate for you already. and about configuration on Router i will be create new topic!!!!
Best Regards,
Rechard
argnetworking Wed, 08/18/2010 - 19:17
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
I don't know if you have solved this. But if you want I have a Pix ASA working with authentication and dynamic ACL authorization. I have created a group in LDAP where I put my users and permisions they have (traffic ACL) and I can assign ACLs in a dynamic way (the pix can add ACLs that reads from the LDAP).
Gonzalo
