Multi route and static route issue
Answered Question
Jul 12th, 2010
How is it posible to send traffic from network 10.90.2.0 and network 10.90.4.0 (Both subnets are connected direktly to router A) to the same destination network from Router A witch static route
via two different interface on router B or router C.
NB: I have allredy a static route on router A - ip route 195.70.240.0 10.80.255.253. Tanks in advance!
sfanayei
Correct Answer by Richard Burts about 6 years 9 months ago
sfanayei
Jon has one understanding of your requirements which is that you need traffic sourced from 192.168.2.0 to go over one link and traffic from 192.168.4.0 to go over the other link. If that is the correct understanding then he is correct that you can not do this with just static routes and that Policy Based Routing is the solution that will work. But I believe that there is a different interpretation of your requirements. As I read your post I think that perhaps your requirement is that traffic should use both links, that some traffic should go through router B and some traffic should go through router C (but that it does not necessarily need to be separate depending on source address). If that understanding is correct then there is a solution that uses just static routes. Configure a static route for the destination with router B as the next hop and configure another static route for the same destination with router C as the next hop.
Can you tell us which of these possibilities satisfies your real requirements?
Rick
Correct Answer by Jon Marshall about 6 years 9 months ago
sfanayei wrote:
sfanayei
You can't do it with just static routes but you can with PBR ie.
access-list 101 permit ip 10.90.2.0 0.0.0.255 195.70.240.0 0.0.0.255
access-list 102 permit ip 10.90.4.0 0.0.0.255 195.70.240.0 0.0.0.255
route-map PBR permit 10
match ip address 101
set ip next-hop
route-map PBR permit 20
match ip address 102
set ip next-hop
int fa0/0  <-- this interface connected to 10.90.2.0 network
ip policy route-map PBR
int fa0/1  <-- this interface connected to 10.92.4.0 network
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Mon, 07/12/2010 - 10:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
sfanayei wrote:
sfanayei
set ip next-hop
set ip next-hop
Jon
sfanayei Mon, 07/12/2010 - 23:57
Dear Jon
Tanks for your reply, i have'nt try your slution yet, but it seems it will work. I have correctet my networg diagram, please take look at it. Do I need to keep my existing static route efter implementing the your solution or I can just delete it?
Tanks again
sfanayei
Richard Burts Tue, 07/13/2010 - 04:49
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
sfanayei
Thank you for posting to the thread indicating that Jon had the correct understanding of your requirements. In this case what he suggests is a good way to satisfy your requirements. I would suggest that you keep the static route. It will not be used to route traffic from either 192.168.2.0 or 192.168.4.0 but would be needed if there were traffic sourced from any other address (such as if you attempt to ping, trace, etc from the router). There is minimal impact in keeping the static route and there is some potential benefit from having the static route.
Thank you for marking the question as resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know from the marking that they  will see responses which did resolve the question.
Rick
Correct Answer
Richard Burts Mon, 07/12/2010 - 13:54
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
sfanayei
Rick
sfanayei Mon, 07/12/2010 - 23:46
Dear Rick
I am sorry that i was not much clear om my message, but Jon's understandig is correct, but tanks any way for your reply. And i have correctet my network diagram.doc too.
Sfanayei
