IP IGMP SNOOPING QUERIER ON A PER VLAN
inshu.inshu
I am using a 4507R cisco switch and I need to enable IP IGMP SNOOPING VLAN 4 QUERIER, which is for my IPTV vlan.
I did try to enable this and get below error. I have an IP address assigned for the vlan 4.
"" Core_AlGosaibi(config)#int vlan 4
Core(config-if)#ip igmp snooping querier
IGMP Querier function cannot be operationally enabled on some VLANs because the required conditions have not been met.""
I see the IGMP version to be 3, will it make any difference?
few are some outputs for your reference, but it doesnt show igmp snooping querier (enabled/disabled) kindly help.
Corei#sh ip igmp snooping vlan 4
Global IGMP Snooping configuration:
IGMP snooping              : Enabled
IGMPv3 snooping            : Enabled
Report suppression         : Enabled
TCN solicit query          : Disabled
TCN flood query count      : 2
Last Member Query Interval : 1000
Vlan 4:
IGMPv2 immediate leave              : Disabled
Explicit host tracking              : Enabled
Multicast router learning mode      : pim-dvmrp
CGMP interoperability mode          : IGMP_ONLY
When I globally enabled ip igmp snooping querier and then enter the command " ip igmp snooping vlan 4 querier " it takes.
But again this command is globally enabled, will it make any issues during query with respect to the query IP address??
Please help.
MI
6 Replies 6
inshu.inshu
Now I see that the the IGMP snooping querier is enabled for all the vlans since I entered it globally, is there anyway in which I can get it enabled for only IPTV vlan which is my Vlan 4? Please advise.
Also operational state is showing non querier, is it because some problems with configurations?
Core#sh ip igmp snooping querier vlan 4 detail
Global IGMP switch querier status
admin state                    : Enabled
admin version                  : 2
source IP address              : 0.0.0.0
query-interval (sec)           : 60
max-response-time (sec)        : 10
querier-timeout (sec)          : 120
tcn query count                : 2
tcn query interval (sec)       : 10
Vlan 4:   IGMP switch querier status
admin version                  : 2
source IP address              : 10.20.4.1
tcn query count                : 2
operational state              : Non-Querier
operational version            : 2
tcn query pending count        : 0
Corei#sh ip igmp snooping querier vlan 8 detail
admin version                  : 2
tcn query count                : 2
Vlan 8:   IGMP switch querier status
admin version                  : 2
source IP address              : 10.20.8.1
tcn query count                : 2
MI
Dear inshu.inshu,
How did you eventually solve this issue? Please I need your help on similar issue.
I have a VLAN for IPTV for which i like configure multicast to be restricted only to the IPTV VLAN.
idrisoye@yahoo.com
Hi Idris,
Enable igmp querier on core switch and immediate leave on the access switch particular vlan.
Inshu,
Many thanks. But I did not understand what you meant in the bold text:
Please explain.
“We should all have the right to free speech and expression of opinions. Wisdom is knowing when, where, and how to use them”
Surya ARBY
Level 4
Level 4
Bump !
Issue still there in the last firmware on sup7; has someone opened a case about this ?
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/15.1/XE_330SG/configuration/guide/multi.html#wp1163784
The doc is clear :
The IGMP Snooping Querier feature can be enabled either globally or per-VLAN.
but it's wrong ! I'm running
D7402_DC#show version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.03.01.SG RELEASE SOFTWARE (fc2)Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2012 by Cisco Systems, Inc. Compiled Sun 26-Aug-12 13:45 by prod_rel_team
System image file is "bootflash:/cat4500e-universalk9.SPA.03.03.01.SG.151-1.SG1.bin"
By default IGMP snooping is Enabled and IGMP snooping querier is disabled :
D7402_DC(config)#ip igmp snooping vlan 4 querier
Command did not take effect due to reason: IGMP switch querier is globally disabled.
So of course I enable it globally; and IGMP snooping querier is applied on all VLANs
D7402_DC(config)#ip igmp snooping querier
D7402_DC#show ip igmp snooping querier
Vlan      IP Address               IGMP Version   Port
1         172.22.248.42            v2            Switch
4         10.160.0.5               v2            Switch
8         172.22.248.42            v2            Switch
9         172.22.248.42            v2            Switch
10        172.22.248.42            v2            Switch
11        172.22.248.42            v2            Switch
12        172.22.248.42            v2            Switch
But when I issue
D7402_DC(config)#no ip igmp snooping querier
the command is deleted from the config but IGMP snooping querier is still active on ALL Vlans; of you want to disable IGMP snoopin querier; you have to disable IGMP snooping and then enable it again if you want to keep L2 multicast forwarding logic
D7402_DC(config)#exit
1         172.22.248.42            v2            Router
4         10.160.0.5               v2            Router
8         172.22.248.42            v2            Router
9         172.22.248.42            v2            Router
10        172.22.248.42            v2            Router
11        172.22.248.42            v2            Router
12        172.22.248.42            v2            Router
D7402_DC#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
D7402_DC#conf t
D7402_DC(config)#
D7402_DC(config)#
D7402_DC#conf tshow ip igmp snooping querier
D7402_DC#
Ferzan Unlu
You also need to specify igmp switch querier source address globally.
