CUCM 7.1(3b) and Maximum supported SIP trunks/Port Numbers
Answered Question
Jul 13th, 2010
Needed to know what is the maximum number of SIP trunks supported on a CUCM 7.1.3b server and/or cluster.
Also, can the SIP trunks be incremented by port number (I know 5060 and 5061 are reserved) - for example, using the same IP address to another 3rd party SIP device, but needing additional SIP trunks to the same server/IP - can I just increment the SIP port numbers?  And if so, how many trunks (Port numbers) can I support to a single IP address?
Thanks.
Correct Answer by Jaime Valencia about 6 years 9 months ago
A cluster consisting of MCS 7825 or MCS 7835  servers can support a maximum of 600 H.323 devices (gateways, trunks,  and clients), digital MGCP devices, and SIP trunks.
A cluster consisting of MCS 7845 servers can  support a maximum of 2100 H.323 devices (gateways, trunks, and clients),  digital MGCP devices, and SIP trunks.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/callpros.html#wp1043871
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 07/13/2010 - 06:52
  • Cisco Employee,
  • Hall of Fame,
    2011
java
