Port Err-disable report from cisco works
Answered Question
Jul 13th, 2010
Hi All,
We have network of around 400 switches.
My question is, Is there any way I can pull up the report of Err-disable for all the switches on Cisoworks ( LMS 3.2).
Any help would be appricated.
Samir
Correct Answer by Joe Clarke about 6 years 6 months ago
No, this is not possible because determining if a port is err-disable is not easily obtainable via SNMP.  Campus Manager's Port Attributes report will show you the operational status of ports, but err-disable ports will be down (which is indistinguishable from a port which is unconnected).
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Thu, 07/15/2010 - 19:37
