Instance numbers following route maps
Answered Question
Jul 13th, 2010
I am working at a client site today, and am trying to prune some routes from one path,
and add them to another.  As I examine the configuration on this specific router, I come across the following:
route-map bgp-eigrp-rm permit 10
match ip address bgp-eigrp
route-map eigrp-bgp-rm permit 10
match ip address eigrp-bgp
route-map eigrp-bgp-rm deny 20
Can anyone tell me here what the 10's and 20"s mean on the end of each of these statments?  What do they pertain to?
Kevin
Correct Answer by Robert Taylor about 6 years 9 months ago
Each route-map can have multiple sequences to it, which dictate the order by which you move through a route-map.
Once the item (packet, route prefix, etc) being sent through the route-map finds a matching statement, it will take the action dicated in that specific sequence, and then immediately exit the route-map.
For example, in this route-map:
If a route DOES match the "eigrp-bgp" access-list, then it will be allowed (this route-map is probably used for redistribution).
If not, it will proceed to the second sequence of the route-map (which happens to be a deny all entry, since no match statement is used in conjunction with a deny type), and the route will not be redistributed.
HTH,
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Robert Taylor Tue, 07/13/2010 - 10:14
  • Cisco Employee,
HTH,
Rob
Kevin Melton Tue, 07/13/2010 - 11:54
Rob
Thanks for the detailed explanation.  It is a big help and makes it crystal clear.
Kevin
