Surendra BG Tue, 07/13/2010 - 09:15
  • Cisco Employee,
Using GUI..
SSID manager >> Configure the SSID >> MAP the VLAN if required>> enable the Radios >> Key Managament >> Mandatory >> Check WPA-PSk >> Enter the KEY >> Apply
Encryption manager >> select Ciphers TKIP >> Apply
Interface configurations >> G-radio >> Enable >> Apply.
Using Cli
dot11 ssid
auth open
auth key mana wpa
wpa-psk ascii
vlan #
guest-mode
Int dot11 0
encryption vlan # mode ciphers tkip
no shut
ssid
exit
corresponding sun interface configurations are required..
https://cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml#pers
No need to have the Radius server if we are using the PSK. (Personal)
Surendra
omgjames1 Tue, 07/13/2010 - 09:26
the GUI is different on a 1130 vs. 1300.
I do not have Key management or the option to click on WPA-PSK only WPA, also, I do not have the option to select Ciphers TKIP.
Surendra BG Tue, 07/13/2010 - 09:33
  • Cisco Employee,
GUI is the same.. in the ssid manager, exactly if we scroll down to half the screen we can see key management.
Similarly if we click on Encryption manager we can see "chphers" i request you to check the link which i posted in the previous post.
Whats is the model number of the AP? is it LAP1131 or the AP1130?
'Surendra
Surendra BG Tue, 07/13/2010 - 09:39
  • Cisco Employee,
dot11 ssid cgap1
authentication open
auth key-mana wpa
wpa-psk ascii
guest-mode
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid cgap1
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid cgap1
dfs band 3 block
channel dfs
station-role root
bridge-group 1
the above config changes will help us.
Surendra
Surendra BG Tue, 07/13/2010 - 09:59
  • Cisco Employee,
Please try with different browser.. if this doesnt work then i request you to upgrade the IOS to the latest
by downloading from the cisco.com
omgjames1 Tue, 07/13/2010 - 11:51
here is what I have so far, but I cannot get to the internet via the AP, I do not even get a screen to type in a key.
Any thoughts?
Surendra BG Tue, 07/13/2010 - 20:12
  • Cisco Employee,
u have not configured the WPA authentication from the SSID manager.
I request you to configure the same.
gjbotimer242 Wed, 07/14/2010 - 07:54
Under Security > Encryption Manager > Encryption Modes you will need to set the mode to "Cipher" > AES-CCMP. Next, proceed to the Security > SSID Manager, choose your SSID, and scroll down the screen. I forgot the exact name of the sub-section, but you'll need to set the first drop-down menu to Mandatory, check the WPA box, and select the version of WPA you wish to use from drop-down menu.
If you are missing any of these sections/options, upgrade your AP firmware to the latest available version from Cisco.
