WRVS4400N and WAP4410N repeater issue
shaun-murray
Hello all...  Here is my issue:
I am trying to connect two WAP4410N Wireless-N Access Points to a WRVS4400N Wireless-N Gigabit Security Router.
I have the following configured on the router:
                B/G/N-Mixed
                Channel 6
                SSID configured with isolation between SSID w/o VLAN
                WPA2-Personal Mixed
                Wireless Isolation within SSID disabled
                TKIP+AES Encryption
                Connection Control disabled
                Allow wireless signal to be repeated by a repeater – Auto
I have the WAP configured as a "Wireless/Client Repeater" along with the security information entered correctly into the web configuration.  However, when I unplug the Ethernet cable, and want the WAP to work as just a repeater, I lose connectivity (continuous pings) to the WAP.  What am I doing wrong?  What do I need to do to configure the WAP to work as an independent repeater for the Wireless LAN?  Thank you for any support in this matter.
Message was edited by: shaun-murray - added information...
shaun-murray
I just noticed on the wireless configuration page on the WRVS4400N, on the bottom of the WDS configuration it says the following:
The WDS feature allows WRVS4400N to connect with up to 3 wireless repeaters that can be either WRVS4400N or WAP200.
Does that mean I cannot use two WAP4410N as a repeater?  TIA
