Codec G729A implementation
Jul 13th, 2010
Hi, im currently using a Cisco 2821 as a CISCO UBE between to endpoints with codec g711ulaw.  I want to migrate to g729a.  I have installed all the necesary pvdm modules, but i think i might be missing something in the config.  Everytime i change the dialpeer to use the g729r8 codec i get the following error:
//209/9F8ADEC68233/SIP/Error/sipSPICreateOutboundSDP: Error in creating an SDP for the outbound call - Check for supported codecs
and
SIP/2.0 501 Not Implemented
please help.  Thanks
Freddy
Freddy Montas Tue, 07/13/2010 - 10:05
here is the config and errors output
voice-card 0
codec complexity medium
dspfarm
dsp services dspfarm
voice service voip
address-hiding
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711alaw
codec preference 4 g711ulaw
codec preference 5 g726r16
codec preference 6 g726r24
codec preference 7 g726r32
sccp ccm group 1
associate profile 1 register test
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 66
associate application SCCP
dial-peer voice 999 voip
session protocol sipv2
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 20 voip
destination-pattern 27
progress_ind progress enable 8
  max-redirects 5
session target ipv4:x.x.x.x
dtmf-relay rtp-nte digit-drop
codec g729r8
no vad
gateway
  timer receive-rtp 1200
Errors output
debug ccsip messages
001025: Jul 13 13:01:03: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:27 SIP/2.0
Via: SIP/2.0/UDP x.x.x.x;branch=z9hG4bKac10fd1a000000aa4c3c9bcf0000078c00000062;rport
To:
Contact:
Call-ID: CC142E53A7C242F5869AB37B55DFADF20xac10fd1a
CSeq: 1 INVITE
Max-Forwards: 70
User-Agent: SJphone/1.65.377a (SJ Labs)
Content-Length: 368
Content-Type: application/sdp
Supported: replaces,norefersub,timer
v=0
o=- 3488029263 3488029263 IN IP4 x.x.x.x
s=SJphone
c=IN IP4 x.x.x.x
t=0 0
m=audio 49194 RTP/AVP 3 97 98 8 0 101
c=IN IP4 x.x.x.x
a=rtpmap:3 GSM/8000
a=rtpmap:97 iLBC/8000
a=rtpmap:98 iLBC/8000
a=fmtp:98 mode=20
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=setup:active
a=sendrecv
001026: Jul 13 13:01:03: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To:
Date: Tue, 13 Jul 2010 17:01:03 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
001027: Jul 13 13:01:03: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: ;tag=39B1B20-7F9
CSeq: 1 INVITE
Reason: Q.850;cause=65
Content-Length: 0
001028: Jul 13 13:01:03: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:27 SIP/2.0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
debug ccsip errors
001029: Jul 13 13:01:41: //212/24727845823D/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo:
failed to update call entry
001030: Jul 13 13:01:41: //213/24727845823D/SIP/Error/sipSPI_ipip_copy_channelInfo_to_sdp:
filter mis-match, failing call
001031: Jul 13 13:01:41: //213/24727845823D/SIP/Error/sipSPIAddSDPMediaPayload: Call Origination Failed: None of the selected codec from CLI is supported by SIP
001032: Jul 13 13:01:41: //213/24727845823D/SIP/Error/sipSPIOutgoingCallSDP: Error with codec types on media line
001033: Jul 13 13:01:41: //213/24727845823D/SIP/Error/sipSPICreateOutboundSDP: Error in creating an SDP for the outbound call - Check for supported codecs
001034: Jul 13 13:01:41: //213/24727845823D/SIP/Error/preprocessSetup: Error during outbound SDP creation
001035: Jul 13 13:01:41: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_spi_process_ccapi_event: CCAPI Event Preprocessor Failure
