uc560 issues with phones
Jul 13th, 2010
hello we have a uc560 and 2 esw switches, poe, 24 ports each.
the uc560 was upgraded to the latest version. we are using cca 2.2.4
these are our problems
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Some of the 525g's are giving the error "Max number of phones registered" this requires several unplug's for the phones to sync up. I have noticed this on all 3 of the phones in the building.
Phones dropping off the network after being left alone for several hours/overnight.
The phones will boot up to initializing network, then get stuck on a blank screen. Checking under network status shows the correct TCP info, several unplugs are needed to resync the phone to the network or rebooting the switches & UC560. Cabling does not seem to be the issue as its random phones around the office and the problem follows the phone when moved.
what do you think is the problem?
