PAM - send events to external application
Jul 13th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
I need to get events information from the PAM to external application, only information I can get is when i configured an URL Action triggered by using the “Invoke Automation Rule”.
Anyone knows how to do that?
Pedro
paulw.wilkinson Thu, 08/05/2010 - 18:05
It would help if you could supply some more information on what you are trying to achieve, but aside from the URL trigger you mentioned, there is a web services event callback available if you purchase the web-services API license for CPAM - http://www.cisco.com/en/US/partner/docs/security/physical_security/access_control/api/web_services/1_2_0/cpam_api_1_2_0.html
  Paul
