Upgrading/Updating directly > is it possible on LMS windows box ?
Answered Question
Jul 13th, 2010
i have 3.0.1 LMS  and i think the latest is 3.2 ? how can i upgrade or u
pdate directly on the same server with minimum scheduled donwtime ?
will it affect the configuration, or is it possible to overwrite with new versions,   ??? i know i have modules of CS , IPM ,DFM,  RME etc...  how will they work with upgrade ? my DCR is standalone and right now my LMS is woring smooth and i have no problems with CS or RME ....
need expert advice... ..?????
Correct Answer by Joe Clarke about 6 years 9 months ago
This document will walk you through upgrading LMS 3.0.1 to 3.2.  Yes, you can do an upgrade on the local server, but it will bring down time.  That down time could be a whole day depending on the amount of data that needs to be migrated.
http://www.cisco.com/en/US/partner/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/instl.html#wp1541453
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 07/13/2010 - 21:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
