do 1242 ap's try to associate with WLC4404 using lwapp then capwap
carl_townshend
Hi all
do 1242 ap's try to associate with WLC4404 using lwapp then capwap, how many times do they try lwapp? I have had them all connected to my controller, I have reboooted my controller and they are all taking a long time to come back on, why is this ?
cheers
They start by searching for LWAPP and then switch to CAPWAP when there's no response.
6 Replies 6
Leo Laohoo
Depends on version of your firmware.  4.X uses LWAPP but 5.X, 6.X and 7.X uses CAPWAP.
When I debug the controller, it says that the access point keeps trying in LWAPP, then after a while it trys in capwap and connects, if the ap's have downloaded the new IOS from the controller, how come they still try in LWAPP first.
cheers
Carl
Hi Carl,
Are you talking about the DNS entry?  If so, then starting from version 7.X it will look for the CISCO-CAPWAP-CONTROLLER for the 1140 (don't know if this is a bug or a deliberate ommission).  Other APs will still look for the LWAPP option.
Hi there
My controller is version 6, I believe they will use capwap now, is this correct ? or if the ap's use lwapp will they use that ?
Leo Laohoo
Thanks for the ratings, Carl.
