moving fwsm to new chassis
Jul 13th, 2010
Planning on moving my standby fwsm to a new 6500 chassis; couldn't find any documentation on the procedure.  The config should be stored on the fwsm (rather than the 6500 itself), so I'm assuming the move should be easy, just a matter of moving the "firewall vlan-group" commands, and reestablishing the failover and state links to the active fwsm.  Is that a correct assumption or is there anything I'm missing?  If anyone knows of a link to Cisco's recommended procedure for this I'd be grateful.
thanks,
Mike
Andrew Ossipov Tue, 07/13/2010 - 12:54
  • Cisco Employee,
Hello Mike,
You're correct that the procedure is fairly easy and should not involve any configuration changes on the FWSM itself. Just make sure that the new chassis is running the software that is compatible with the FWSM code.
Andrew
ippolito Tue, 07/13/2010 - 13:22
Will do, thank you for the confirmation.
Mike
Related Content
