Video Conference timeout after 2 hours
Jul 13th, 2010
I'm having a problem where video conferences are timing out after 2 hours and 12 minutes consistently.  I've located a number of solutions for adjusting the h323 timer on a PIX in order to solve this problem.  My issue, is that I don't have a PIX, but a 3845 router running IOS
How can I perform the equivalent command on IOS that you would perform on a PIX, which is:
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 0:00:00
timeout h323 16:00:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
1 vote
Kevin Redmon Wed, 07/14/2010 - 06:05
Just to confirm, what IOS firewall are you using?  If you are using CBAC, 'ip inspect tcp idle-time ' may be what you are looking for.  If you are using ZBF, the command would be 'tcp idle-time'.  Consider the links below:
CBAC 'ip inspect tcp idle-time':
ZBF 'tcp idle-time':
By default, these are set to 3600 seconds.
If this addresses your question, please let us and other NetPro users know by marking this question as answered.
Best Regards,
I do not think this is a tcp idle timeout issue?  I am currently experiencing the same problems with an inter company Pix firewall which I do not have access to.  what version IOS are you running?
I also ran into the same problem 6 years back - The VC would time-out after 1:59:59.  Along with the session timing out because it had reached 2 hour mark, hitting the mute button on the VC unit also caused the session to drop.   The  FW at that time was a Checkpoint and an upgrade to SP3 fixed the issue.
The dafult TCP timeout setting of 1 hour is being talked about here is for an "idle connection"
Jitendriya Athavale Sat, 07/17/2010 - 07:14
please increase the tcp idle timeout to more than 2 hrs. this happens in stateful firewalls as in video conferencing every 2 hrs a packet(something like keep alive) is sent, i dont exactly remember the name but i think it happens on port 1720 or something like that. so if the timeout is less than 2 hrs the keep alive is droped and connection terminates
one option would be allowing the ports required for video conferencing in both directions
The tcp idle timeout is not the problem:
Polycom sends a H.225 packet at just after the two hour mark during an active call. If the H.225 port was closed by the firewall due to inactivity the Polycom will not get a response and drop the call. Set your H.225 timeout to something higher than 2.5 hours and all will be well.
By default the ASA/FWSM gets the following timeout lines.
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
BTW, the one I would be suspect of is the timeout conn 1:00:00 which by default closes a session after an hour.
Jitendriya Athavale Mon, 07/19/2010 - 10:24
exactly, that is what i was refering to and i have seen it happen before when the conn timeout is less than 2 hrs
