Port channel and trunking question
Answered Question
If I wanted the ports in my port channel to be trunking, do I have to specify "switchport mode trunk" on each port or can I just specify it on the port-channel interface?
Correct Answer by Amit Singh about 6 years 11 months ago
On all the interfaces. Different IOS have different behaviour. In older IOS, I used to do it only on the port-channel interfaces. Sometimes you get wiered behaviour if you are coniguring on different switches. As a best practice :
1. Shutdown the interfaces manually.
2. Configure all the ports as trunk ports.
3. Configure the port-channel parameters.
4. Configure interface parameters if required like speed/duplex.
5. no shut the interfaces.
This should work like a champ.
HTH,
-amit singh
Overall Rating: 5 (1 ratings)
Correct Answer
Amit Singh Tue, 07/13/2010 - 14:48
  • Cisco Employee,
HTH,
-amit singh
Ganesh Hariharan Tue, 07/13/2010 - 23:00
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Amit has given the step by step procedure for configuring the port channel in switches and just check out the sample example in the below link hope to help !!
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094958.shtml
Ganesh.H
