H323 Gateway outboud dialing not working
Jul 13th, 2010
I have a new install of h323 gateway with CUCM 7.X. I am testing with only one FXO voice port 0/3/0. Inbound calls work, but I cannot get outbound to work and CUCM is sending the correct digits to the H323 GW and it is matching the dial-peer. Number called was 92345966 from ext 1002
I have attached the relevant portions of the config, with a debug voip ccaip inout
what am i missing
Cheers
Nki
lavanyaps Thu, 07/15/2010 - 06:16
Hi Nki
Your configuration seems to be ok. Can you tell me the end to end call flow from which phone (1002) are you making the call and where
are you terminating 92345966 (mention type of phone) involving all the H.323 Gw IPs ?
Also give me debug voip ccapi inout for one call..   based on you debug output i can see the call is landing on the dial-peer but
failed to reach the destination number 92....  could be a parameter setting based on the end device.
Nkechi Latunji Fri, 07/16/2010 - 05:04
My config was correct, customer was not providing a direct POTS line from Telco, but one from their legacy PBX. So I stopped stipping 9 from the pattern and allow their legacy pbx take care of that.
Cheers
Nki
