07-13-2010 08:05 PM - edited 07-03-2021 06:58 PM
Howdy.
We have two Cisco 1310 devices working currently in point to point mode. I have a couple of questions regards this..
1. What is the best method to encrypt the point to point links between the two? We would like to use local passwords for this.
2. We have two point to point links on each device. Would we be able to configure one link for encryption without dropping our connection to that device and then configure the second one?
3. Is there any sample guide for point to point encryption?
Many thanks..
Taff.
07-13-2010 08:10 PM
ANS - We can use Ciphers TKIP as the encryption and WPA-PSK as the authentication.
ANS - I request you to brief me out on "we have 2 P2P on each device" does this mean we have 2 SSID configured??
Surendra
07-13-2010 08:38 PM
Thanks for the quick reply.
Yes there are 2 ssids on the device.
07-13-2010 08:46 PM
no problem.. we need to create the sun interfaces and map the SSIDs to respective VLANS, thei will solve our issue.
the link which i provided in my previous email may help you. Is der anything else that i can help you with?
Surendra
07-13-2010 09:56 PM
Nope that's all good.. Thanks.
07-13-2010 09:59 PM
thats great
Have a nice day / Evening or afternoon
Plz rate the post if this solved your issue.
Surendra
05-29-2011 07:34 AM
Please mark the Question as Answered if the provided information is correct and issue is fixed.
thanks,
Vinay
