Softphone in CUCIMOC not working
Answered Question
Jul 13th, 2010
Softphone in CUCIMOC not working after the changing the Directory number for CSF device. Desk Phone control works fine, when toggled to select soft phone, it greys out and status shows it is not connected, and at the bottom of the screen it still shows old extension. Wondering if there is any cache that needs to be cleaned
Correct Answer by htluo about 6 years 7 months ago
CUCIMOC refresh the configuration when CSF restarts.  Have you killed cucsf.exe from TaskManager?
Michael
http://htluo.blogspot.com
Overall Rating: 5 (1 ratings)
Rajesh Revuru Thu, 07/15/2010 - 06:59
Mike:
Yes i did kill the CuCSF.exe process and restarted again, and no luck, so i ended up opening a TAC case and we had to rename the user.properties file and also we have deleted CSF phone and re-added with a different device name and it worked.
Thanks a lot
