ospf lsa 3 and 4
Jul 13th, 2010
Could some one  explain what is the exact difference  between lsa 3 and lsa 4  and what is the significance of each of these lsa and when  will theese lsa come into the picture
Overall Rating: 5 (1 ratings)
Nagaraja Thanthry Tue, 07/13/2010 - 21:02
Network Summary LSA (Type 3)
– Generated by Area Border Routers
– Sent to an area to advertise routes belonging to other areas
- Also used by the ABR to advertise subnets that are part of another area to the backbone area
- Network summary LSA also contains default routes
– ABR includes cost from itself to the network it is advertising in the LSA
– When the ABR advertises the summary LSA to routers within an area, the internal routers do not run SPF again
- Internal routers just add cost from them to the ABR
ASBR Summary LSA (Type 4)
– Advertised by the ABR
– Contains information about the ASBR Router
– Always the advertised address will be a host not network
- Used in conjunction with Type 5 LSA
So, essentially Type 3 is used to advertise routes external to an area (including default routes) whereas the Type 4 is used to propagate the information about the ASBR router. When the internal routers get routes distributed via another routing process, using Type 4 LSA, they determine the router that has redistributed these routes.
Hope this helps.
chinkevi_2 Tue, 07/13/2010 - 22:37
in other words, in an internal router, when you check the lsa database, you would expect:
- type 3 lsa has a list of networks in other area
- type 4 is the rid of asbr, so the router know which rid is used to pass routes out of ospf domain.
