problem with auto qos
Jul 13th, 2010
     I am facing a big problem with auto qos command.We are using on cisco ISR routers which are installed at leased line link of diffrenet bandwidths.voice and data are working on both routers.
     The problem is :- When i'm using auto qos voip on serial port both routers, the leased link will go down immidiately.If i will remove auto qos voip commands from both routers, the link will UP soon.
                              I'm not getting the actaul problem, what is happening and why is happening.
                               Plaese any one help me in this maater, so that i will implement right solution.
Siddhartha Singh
siddindia Tue, 07/13/2010 - 22:52
       The strange thing is:- when i use command show ip int brief, it will show port and line protocol  will UP but im unable to ping other side of router.
What exactly it is?
siddhartha
