2851 and NM-HDV2 modules
Jul 14th, 2010
Hello all,
I have plugged a NM-HDV2-2 T1/E1 on slot1 on a 2851 router.
IOS does not recognize, it tells me that there is a "unknown" module. My IOS is SPServices 12.4
Any help?
Overall Rating: 3 (2 ratings)
Leo Laohoo Wed, 07/14/2010 - 02:32
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
This is information is not complete.  You need to use the "T" train.
Please don't forget to rate useful posts.  Thanks.
mcecilia Wed, 07/14/2010 - 02:49
Sorry,
More detail about the version:
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(22)T4, RELEASE SOFTWARE (fc2)
Nagaraja Thanthry Wed, 07/14/2010 - 06:42
  • Cisco Employee,
Can you please post the output of "show diag" from the router here?
NT
mcecilia Wed, 07/14/2010 - 07:47
Now I can not get the show diag, but before I runned it and in module 1 (where it was plugged) it said something like "unknown module". I will update with the result may be in some hours.
Also I tried to plug into Module 2, but, strange, it didn´t fit.
Thanks for your help.
Brandon Lynch Wed, 07/14/2010 - 09:23
  • Cisco Employee,
Per the following link, this card was first supported in 12.3T code so you should already have support for it in 12.4(22)T4 -
http://www.cisco.com/en/US/partner/tech/tk652/tk653/technologies_tech_note09186a008039c333.shtml#PlatformSup
I presume that you are powering the box down, installing the card, and then powering it back up.  Are you seeing any errors with regard to this module on boot-up?
Brandon
mcecilia Thu, 07/15/2010 - 22:55
It is strange how was solved. Tried to unplug and plug the module several times (of course, with the 2851 powered of). Then, as I had not result plugged it in another 2851 and worked. Then, in the first 2851 and ... worked.
Thanks all for your help.
