07-14-2010 01:14 AM - edited 03-06-2019 12:01 PM
POST: PortASIC RingLoopback Test: Begin
TCAM (asic:3, bit:5) address bus test failed
From what is it getting in mistake?
what deffect is it in it?
_____________________________
Bayasgalan.B
Solved! Go to Solution.
07-14-2010 03:16 AM
07-14-2010 02:09 AM
You need to get a TAC raised. The switch has just suffered a catastrophic failure.
07-14-2010 02:53 AM
Bayasgalan.B
Hi Bayasgalan,
This is an hardware failure of TCAM address bus you need to replace the switch,any other logs at the booting time in order to have clear idea.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
07-14-2010 03:16 AM
Hardware Failure !!
Please raise an RMA !!
Cheers,
08-10-2010 12:20 AM
Please help me!!!
what's the reason of this kind of defect?
B.Bayasgalan
