cisco callmanager expres 4.0(1)
Answered Question
Jul 14th, 2010
I'm a registered cisco user.
I'need to download the software in object.
which one say where i'can find it in the Cisco web site?
thanls in advance
giancarlo
Correct Answer by Aaron Harrison about 7 years 1 week ago
It's not quite clear what you want to download, but try this:
Gt to : www.cisco.com/go/software
click on 'Voice and Unified Communications'
Browse to IP Telephony/Call Control/Communications Manager Express
All the CME downloads are there...
Aaron
Please rate helpful posts..
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Wed, 07/14/2010 - 03:20
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
gevangelista Wed, 07/14/2010 - 03:31
i've a cisco 1751-V.
This otuer support the cme 4.0(1), but on the site the lower release is the 4.1.
It's this release supported from my router?
Aaron Harrison Wed, 07/14/2010 - 03:38
THis page lists each of the CME versions; you can click on the link to the 'specfication' document that lists the supported platforms.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
According to those documents, the last version to support the 1760 was 4.0(2); 4.1 doesn't list the 1760 as supported.
Aaron
gevangelista Wed, 07/14/2010 - 03:51
My router is a Cisco 1751-V and not 1760!!!!!
And ther latest version of cme supporte by this router is the 4.0(1); and the 4.0(1) are not on the cisco site!
