NAC upgrade 4.6.1 to 4.7.2
Jul 14th, 2010
I have a problem with upgrade CAS 4.6.2 to 4.7.2.
When I unpacking cca_upgrade-4.7.2-from-4.5.x-4.6.x.tar.gz and started ./UPGRADE.sh, I get message on console:
Checking for a free partition to use for upgrade
Found free partition to use at /dev/sda3
Free partition size is 2040255 kb
Free partition lies outside the boundaries of partition 4 in new layout
Free partition cannot be used for upgrade image safely
Exiting
(Cisco NAC appliance 3310 | server)
Alexandro Cher
Faisal Sehbai Thu, 07/15/2010 - 06:18
Alexandro,
That doesn't sounds good. Did you verify the md5sum of the file you downloaded for upgrade?
Faisal
a.chernomazov Thu, 07/15/2010 - 19:18
Faisal, thanx a lot for the reply.
File cca_upgrade... it's ok!
Upgraded CAM is fine.
CAS.....problem.
Best regards
Alexandro
