Cisco WCS: How do I export Floor Maps?
jay_finley
I cannot find an export utility within WCS.
Ganesh Hariharan
Check out the below link hope to help !!
http://www.cisco.com/en/US/docs/wireless/wcs/4.1/configuration/guide/wcsmain.html#wp1086649
Ganesh.H
Remeber to rate the helpful post
tdorsey123
Old Post but i thought I'd add this update for WCS v 7.0.220, you can search for export in the WCS GUI online help and get...
Exporting a Map
The Export Map feature allows you to export map or calibration information to XML. The exported  XML will be in an encrypted format and will not be readable. XML and images are bundled, tarred, and  zipped into a file for a successful import into another WCS.
To export a map, follow these steps:
  1. From the Monitor > Maps window, select the check box of the map that you want to export.
  2. From the Select a command drop-down list, choose Export Maps. The Export Map window appears.
  3. Select the maps that you want to export.
  4. Click Export to export the selected map data.
